How to fix a laser mouse
hello guys i just want to know how to fix a laser mouse ? one of my mouse is very hard to control and its so hard to click the 2 buttons or should i buy a new one? i really need a mouse right now .
       Go to Start -> Control Panel. Click "Uninstall a program."
Good day!!!There`s a few steps on making your laser mouse work again. One of the solution is on the device managers list try uninstalling the mouse. The next thing is to try rebooting the mouse while its un- plugged. After that, go back to windows and try to plug the mouse back. Re-start your computer.  If this doesn’t work try putting another mouse for us to see which one has defects, the mouse or the pc. Or might as well try the mouse on another computer just to make sure.  Don’t forget to check the battery too. Thank you I hope this helps. 🙂
