How to fix license problem of Adobe CS4?
What should I do when my license of Adobe CS4 Master Collection expires though it is the first time I install it and having a hard time to open any program?
If you are facing this problem then your license key is not updated. You should contact with adobe and tell them about your problem, they will definitely help you out. Adobe always helps people, who are facing problems using their products. If you are having an illegal copy with a manipulated serial key then you should buy a legal copy of Adobe CS4 and uninstall the old copy completely from your system using complete Removal software (I always prefer revo uninstaller). Install the adobe CS4 with the legal serial key and update the patch regularly; you won’t face this type of problem again.
Hope for the best….good luck!!!!
This problem might happens because of the updater is only update the retail version and not for the prerelease (beta) version. There are few suggestion solutions. One of it is by set the FLEXnet Licensing service to manual and start the service. First, go to Start>Control Panel>Administrative Tools>Services>FLEXnet Licensing Service. Then, the Properties dialog box will reveal. Click on the startup menu and select manual. After that, click Apply>Start>Apply>Ok. Close all open dialogs and launch your Adobe application.
Another way that you can try is you have to rename or delete the folder in the virtual store. Browse to C:Users[user name]AppDataLocalVirtualStoreProgram Files (x86)Common FilesAdobe (or just C:Program FilesAdobe if you share the computer). After that, launch the adobe application. If still cannot be resolve, don’t hesitate to contact Adobe Technical Support.
Did you purchase the product or downloaded the trial version? If you purchased the program then you will need to renew your license. If it's a trial version, you will also need to purchase it to use the complete features. If you are encountering issues on opening other software and you think that the reason for this is the Adobe product, then remove all the Adobe Master Collection components and then purchase and re-download it again from the Adobe website. You can find the links from the forum given below:
