How to fix Load lang.xml failed error when opening Notepad++?
The following beginning of a message that appears whenever you open notes Pad in Windows 7 64 bits:
Configurator
Load langs.xml failed!
Why did it do it? I cannot identify with anything on this.
Please explain more…
May be your langs.xml has error into it. It might happen when you made any unintended changes in Notepad++ Options.
Here is the solution:
1. Close Notepad++.
2. Right click on Notepad++ shortcut Icon and click Open file location.
3. Rename langs.xml to langs.xml.update
4. Find langs.model.xml and make a copy of that. Rename the new file as langs.xml
5. Restart Notepad++.
Hope It will work for you.
Thanks!!
