How to fix lotus notes dxl Microsoft word on 2010
Hello expert, I am using MS word 2010 on my lap. I need some Lotus notes DXL to fix on it. So, please can you guide me how to fix lotus notes dxl Microsoft word on 2010 version?
Make sure you have installed MS Office BEFORE installing Notes. If Notes has been installed before, uninstall it then install MS Office then install Notes again. In Notes, choose a location where you usually send and receive mail (or create a new location).
Go to File > Location > Manage Locations > Advanced > Locations. Click on the current location, then on Edit, then on Advanced. Type in your User ID file name in the User ID field then click Save & Close.
Go to the Start button then Control Panel. Double Click on Mail/ Mail and Fax and add Lotus Notes Mail.
You can get more information here.
Hello Grant,
As you have mentioned you want lotus note dxl on your laptop. You can simply download it from the internet just make sure which version you need. Let me tell you, there’s no need to worry about which version of ms word you are using because lotus notes support all versions of MS word. Hope this will help.
Good luck.Â
