How to Fix Microsoft Office 2010 Starter Does Not Open ?
when i try to open MS-OFFICE 2010 ,i get this error and i can`t open it.
WINWORDC.EXE
WIN WORDC.EXE has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Close program
Best Answer by CurtinnJohn
Answered By 0 points N/A #168891
Try reinstalling the program again. It may have developed a bug. If possible, try upgrading to Office 2010, as the starter version has many limitations, including not being able to:
  1. Create PowerPoint presentations
  2. Send emails or keep track of calendar with Outlook
  3. Organize notes with OneNote
  4. Use macros
  5. Modify the toolbar
  6. Retrieve external data from Excel
Answered By 0 points N/A #168893
Hello, Zozamo2012!
There is no any other way of reinstalling this software. You may face this problem again if you uninstall it normally because there are some elements of the software that were kept in the registry. So it is really necessary to use advanced system care or CC cleaner. After doing so, you have need to perform a fresh install of the software.
Thanks!
Answered By 0 points N/A #168892
To fix this, start your MS Word in Safe Mode, and then press Ctrl to launch MS Word. If it works, the issue is due to a 3rd party add-on. To disable this, follow the steps below:
1. Click File> Options> Add-in and then click Go on the Manage menu and then Com-in Add.
2. If you find any add-ons, untick the check box to disable them.
3. Close MS Office and then re-open it again.
4. You have to add a check to the list of the Add-ons and then restart MS Office again and repeat the same process again until you finally identify which add-on is causing the issue and then disable it.
Answered By 0 points N/A #168894
Hello Zozamo,
I faced a lot of this kinds of problem. I think its an error of your downloading MS Word perfectly. So you can reinstall this software and i think this problem will be solution. You can also downloaded update version on internet. I think this solution are helpful to you.
Thanks
Nazmul
