Dear TechyV Experts,
I want to ask for your technical assistance. Whenever I convert a word file to PDF it's always pixilated and blurry, how can I possibly adjust the setting so it would be clear even if I zoom it to a 250%? Please help as soon as possible.
Thank you all!
rajkumar
How to fix a pixelated PDF?
Dear Jersey
I suggest you to convert the document to PDF using non GDI+ technology.
I prefer Microsoft 2000 is the easier platform were you can view the document 250+ zoom in PDF.
Or else I would suggest you to download few templates from openoffice.org.
Best of luck.
Rajkumar
Click over the “Pan and Zoom Window” option, then the Pan and Zoom dialog box can look on your own screen. Enter something to improve the zoom level in the “Zoom” text box, for instance “100%” or “75%”, then the zoom level will automatically change.
Click the “OK” button to close out of the dialog box and save your changes. You can also click on the “plus” or “minus” buttons in the top toolbar to change the zoom level.
For additional help, I would suggest you just reinstall the software, it may allow you to "fix current install" and if you get that option, do it right away. The problems are closely related to your processor. You possess an Intel Core Duo on the MacBook Pro.
Photoshop requires at least an Apple Core 2 Duo model with 64-bit support.
Thanks
