How to fix a problem on sony vagas pro8
I have Sony Vegas pro8 and edited it. When I put an effect on my Sony Vegas pro.8, it works apart from box of the screen.
How do I fix it?
How do I fix it?
You have to be more specific in what type of thing or editing you want to do.
I have been involved in a lot of editing and it is very hard if you just say that you can't put the desired effect on a particular video.
But in general I try to help you here. First select the Layer on which you want the effect to be putted.
Then select the Video on which you want to put the effect.
And then put the desire effect on it. If you are still in confusion, take a look at my YouTube channel Gutsyboy000.
I have made few basic Sony Vegas tutorials which will surely help you out.
Just like any video editing software, when you are editing a section of a video and you apply an effect, the effect you applied is not literally inserted or merged into the video layer or section of the video or project. It normally goes to the overlay section or layer in the exact position or time where you want the effect to appear.
When the project is played back the video section and the overlay section plays simultaneously therefore producing the outcome of the effect. If the effect you applied didn’t appear on the part of the video where the effect should still be visible, you need to modify or adjust the length of the effect.
You can normally stretch or drag the end of the effect up to the time where the effect should disappear. You can preview the video until you reach your desired output.
Notifications
