How to fix prompt for pressing F1F2 at startup?
50 points
Posted on - 02/10/2015
I'm having a problem with my desktop PC. Each time I start my PC, I always need to press either F1 or F2 in order to start the PC. 'Pressing F2 will load default settings', says the screen. If I press F1, I get the BIOS screen. Why is this happening every time? My PC is new and is powered by i5, 4GB RAM if it helps.
