How to fix Runtime Error?
I have got some runtime errors while using Internet Explorer.
But I want to get rid of these errors.
Do you have any tips?
Thanks in advance.
Thanks in advance.
Hi Alisa Pitzer!
Resetting your Internet explorer will fix this problem.
Take note that resetting your Internet explorer will remove your personal settings and will disable your add-ons.
Follow the steps below:
1. a. In the Internet Explore, click Tools.
   b. Go to Control Panel and click Internet Options
2. The Internet Options dialog box will appear. Click the Advanced Tab.
3. Click the Reset Button.
4. Restart you Internet Explorer.
Note: If you want to delete your personal settings as well, check its box in the Reset Internet Explorer Settings dialog Box before clicking the Reset button.
Method 2
1. Download Microsoft Instant Fix here
2. Run the executable file, then follow the instructions in the wizard.
3. Â In the Reset Internet Explorer Settings dialog box and click Reset.
This "run time error" has pissed me off many times and i didn’t know what to do
I am very thankful to Jamelia for helping me.
Thanks to techyv.com too.
