G Racho
Posted on - 10/17/2016
Internet and gaming is one of the thing, this generation depends on. Xbox is the most popular game series. But if a scratch arises on the CD, issues appear in the game. How to fix a scratched Xbox game?
G Brown
10 points
How To Fix A Scratched Xbox Game To Continue Gaming.
THE FOLLOWING WAYS ARE USED TO REMOVE SCRATCH FROM XOX GAME
1) WITH TOOTHPASTE
Use toothpaste which does not contain whiteners. Chemicals can damage the Xbox disc.
Take a microfiber cloth and put toothpaste on it.
Spread this over the disc in even manner.
After 10 minutes, remove the paste using clean water.
Using a microfiber cloth, dry the disc.
2) WITH LIP BALM
This is used as the wax fills the scratch.
Clean the disc with water.
Remove the dust particles by drying it using microfiber cloth.
Apply the lip balm in straight lines.
Remove the wax after some time using microfiber cloth.
3) TURN OFF AND ON AGAIN
It is the most common way to solve issues in electronic gadgets.
Take another Xbox game and put the new disc in your game.
Go to the game controller and boot the device.
Turn off the Xbox and wait for some time.
Restart it and confir m if the disc works.
4) USE A SCRATCH REPAIR KIT
Such kits use isopropyl alcohol to clean the disc alon with microfiber cloth.
They are used to resurface damaged video game discs.
