How to fix script errors on internet explorer
When you receive, webpages may not be shown or work properly in Internet Explorer. The script, errors may have various bases. So I use the internet explorer how can I script error comes after some interval I tried to solve the problem but I cannot. Also can tell me the way how to disable it.
Answered By 0 points N/A #185497
Step 1: Make sure that script errors happen on multiple web pages
If the only sign of this problem is the error message, and if the websites are working, you can probably ignore the error. Also, if the problem occurs on one or dual webpage, the problem may be caused by those pages. If you select to ignore the errors
Step 2: Make sure that the problem is affected by files or settings on your computer
To narrow down the source of the difficulty, use another user account, another browser, or another PC to view the webpages that started the script error.
And problem will be solved.
