How to fix some dvd video soft downloading error?
Hello friends,
How to fix some dvd video soft downloading error? I cannot continue the downloading process, I tried two times but still when the bar reaches half of the process it will automatically crashed and will not respond anymore.
Thanks and Regards,
Jayden Horribol.
Best Answer by goerge rait
Answered By 5 points N/A #181343
One major issue might be your bad or slow “Internet Connection” if so then check your internet proxy settings. Turn off the unwanted monitoring services which sometimes occurs error. “Fix Windows Registry” it will also be helpful for you. Check if there is any malicious software in your computer uninstall it.
Hope this will help you to figure out your problem.
Answered By 10 points N/A #181344
I think you are trying to download a software form the network in this case you need to check your connection and make sure it is working properly. Try to download with download managers and make sure you are downloading a valid file from the network.
Smith Thompson
