How to fix the support of applications of Photoshop error files.
Sometimes faced this error message to initiate Photoshop and salt this error.
Adobe Photoshop
One or more files in the Adobe Application Support folder, necessary for running Photoshop, are missing. Please run the Photoshop installer and re-install Photoshop.
What is this error message? Someone has a good solution, please explain clearly.
How to fix the support of applications of Photoshop error files?
Hi Rowen Briones Prado’s,
The problem is the /Library/ScriptingAdditions/Adobe Unit Types.osax this is not working or not loading so that the file is actually missing. If your operating system is Snow Leopard
it requires 64 bit version every plug-in, include the osaxes. So, to fix your problem install the 64 bit version of the adobe unit type, then if you finish downloading 64 bit version.
You can drag it to your Scripting Additions folder then start your Adobe Photoshop. Thanks.
Regards
