How to fix the wifi will not connect
Hotspot's or surf using WiFi connection is no longer the steps and weird stuff. At the mall, cafes, hotels, terminals, airports, cafes and even in schools we have available WiFi access both free and paid.
Using WiFi Access (especially free ones) is exciting, but also easier we do not have to mess with a LAN cable problem, stay on Laptop WiFi enabled, wait until the scanning process is complete and we can finally connect to the internet and starter surfing in cyberspace.
But there are times when we have WiFi problems, such as can not connect or connect WiFi already, but it turns out we cannot surf.
How to fix wifi solutions that do not want to surf?
Answered By 0 points N/A #86018
Hi Tronkie,
I've already encountered your problem. I hope that this idea I would share with you will fix the problem of your WiFi.
Try to follow the steps I wrote here.
1 – Try to disable the Local Area connection and only the WiFi is enabled. Maybe your Local Area Network and WiFi have conflict to their IP Addresses.
Windows Updates
2 – Try to Update the drivers of your Internet Adapters. Or set the (Time and Date) of your PC at exact (Time and Date) to your location.
3 – Or try to uninstall your WiFi Driver and reboot your PC. And let your PC install the driver of your WiFi. And try to update your Operating System.
4 – Change the IP Address of your WiFi and Local Area Network. Or Better to Obtain their IP.
Good luck!
