rubelahmed
Posted on - 09/27/2011
I am using Windows Vista operating system. Sometimes it shows some error codecs. A message is shown on the screen and when I move the message bar it stretches through out the screen. What is the exact cause of this problem. What should I do to fix this error codec?
smith84
How to Fix Windows Error Codes ?
It is quite obvious that your machine is infected by virus; you should install an Antivirus, which should be updated. Try scanning your system. It is more likely that your Antivirus will detect all threats found in your machine but won’t be able to recover damaged system registry. For recovering registry entries damaged by viruses you should repair your Windows or reinstall your Windows if repairing is not convenient for you.
Another solution is try to restore your PC to that point about which you are sure your PC was working well. System will be restored and you can install Antivirus to protect you PC against viruses in future.
Try It!!
