roni35
Posted on - 09/27/2011
I am using windows XP operating system. Sometimes I face some problem. A common problem is windows installer error. When I try to install a program a error message open which tells windows installer error.
What is the cause of this problem?
How can I fix the problem or what type of program should I install?
Windows Installer
The Windows Installer Service could not be accessed. This can occur if the Windows Installer is not correctly installed. Contact your support personnel for assistance.
How To Fix Windows Installer Error ?
You can reset your installer. what you have to do? The problem you identified is that when you install a program your installer error occur and window display a message box that window installer is corrupted and the program can't be install correctly. This is very common problem to every third to fourth person. what you have to do is, go to Microsoft official site and search for the " how to fix the window installer problem"?.
They have provided good detail of this and also have a software to recover this error but if you don't have the facility of internet then what you can do you have to insert you window cd in your cd room and install a fresh copy of your window. That can also solve your problem but i recommend the first method is the best solution for this problem.
Thanks for asking in www.techyv.com
In Microsoft Windows XP and any versions of Microsoft Windows, if you keep getting an error related to Windows Installer whether you are installing an application or uninstalling, try updating Windows Installer to fix the problem. One way of updating Windows Installer is to update the operating system by installing the latest Service Pack. Installing the latest Service Pack also updates or installs the latest Windows Installer.
To install the latest Service Pack for your operating system, download one of the following Service Packs:
