How to fix Windows XP error message?
The problem is in the Operating System. It may be corrupted. This may happen if the computer wasn't shut down properly. Now you have to install the operating system into the C drive. While purchasing the computer, there should have been a bootable CD provided to you. You will need this to reinstall the OSÂ (operating System).
If you still cannot format drive C after choosing primary boot source in BIOS setup, then find another copy of bootable CD from others to continue the whole process again. Hope you can use your laptop now.
If you still cannot format your C drive, then stop doing anything. It may be a hardware problem (RAM / Hard Disk / Processor / Motherboard). If you have a warranty or guarantee then place it from where you bought it for replace or repair.
If you do not have a warranty or guarantee then go to an authorized service center for HP laptops, they will tell you what to do next.
According to the description of your problem you have written; it should be the Operating System the main problem area. After formatting the C Drive the problem should be solved. But If you still cannot run your computer then it may be hardware components of your computer that may have been affected. It may be RAM or Hard Diskj or Motherboard or Processor. If you place it to a service center they will thoroughly check and will tell you where is the problem and according to their instruction you decide what to do.
Hope this will help you and solve your problem.Â
Thank you.
Here’s how to troubleshoot your PC.
Check the IDE or SATA cable and the power cable of the hard disk inside the CPU case; replace a new one if needed, make sure you place it correctly.
Now reboot your PC, if it’s still have no changes then do the next step. If you have a your windows XP installer then put it in your CD or DVD Rom drive, Restart your PC, while in boot mode press F8 to display all you’re drive available,
Choose your CD/DVD Rom drive to be booted first,
When you choose the CD to boot and the windows installer is in the CD drive then you will a message just like this,
Just hit enter or any key to perform a windows XP setup, it will show like this,
Just press enter and to the other page press F8,
You will see now on the list your windows XP that currently install in your PC,
Just click R in your keyboard to perform a repair in your OS, now after the repair is done it will restart automatically, after that your windows XP is back to normal.
Hello Dear,
Thanks that you have shared your problem with us on this growing IT website.
Sometimes dust becomes the reason of this error.
Kindly first open your computer's casing and clean it with the help of a blower.
After this if you still encounter this then you have only one option to reinstall windows.
I hope it will helpful for you.
