How can I fix the error 0x800710FE?
I'm trying to delete a file, which is from a folder – redirected to a network share.
I use windows 7 and I receive this error message:
Delete File
An unexpected error is keeping you from deleting the file. If you continue to receive this error you can use the error code to search for help with this problem.
Error 0x800710FE; This file is currently not available for use on this computer.
Type: WIriRAR archive
Size 0 bytes
Date modified: 23/01/2010 338 PM
Try Again Cancel
How to fix WinRAR error
To fix the error code 0x800710FE, you may try the following:
To use the PC Cleaner Pro, please do the following:
Hi Carson Fernandez,
In Windows Vista or Windows 7 when deleting a folder or file from a folder that is redirected to a network share you may experience the following error:
An unexpected error is keeping you from deleting the file. If you continue to receive this error, you can use the error code to search for help with this problem.
Error 0x800710FE: This file is currently not available for use on this computer.
To resolve this problem perform the following steps:
1. Click Start and enter regedit in the start search to open Registry
Editor.
2. Expand to
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionNetCache
3. Add a new key:
Key Name: FormatDatabase
Key Type: DWORD
Key Value: 1
4. Restart the computer then the CSC cache is rebuilt. Test the same issue again.
If this does not resolve the problem try uninstalling anti-virus software as there has been known cases where AV has caused this problem.
Regards.
Hi
There is another Techyv post which is also addressed about this issue. So go that page and get more helpful techniques to fix this issue successful.
How Can I Fix Error 0x800710FE?
