How to fix wireless connection error/issue?
Hi All,
I have started to have an issue with my wireless connection. Actually, I have the Wireless on my laptop and it is not been able to find the wireless connections around me. Whereas, I am still able to use them properly on other devices such as my cell phone etc.
When I use to make a wireless connection via my laptop, it sometimes connect but probably not more than 15 minutes or even less than this. And even whenever I try to connect again, it no longer detects any connection or modem not at all. Moreover, as a result those connections which were available in the beginning got lost.
For overcoming this issue I tried to connect again and again approximately four to five times and than I got connected for a while but again my wireless connection was break. I have checked my laptop wireless configuration carefully and they are set as defaults. The conclusion is that I have adopted all the technical methods already, which I know but I have got nothing to overcome this issue.
So, I want to know how to fix wireless connection error/issue?
I hope you can help me to get out of this problem. If anyone has any idea of what might be the problem and how could I fix it?
Then, please suggest a solution as early as you can.
