fox clard
10 points
Posted on - 12/26/2012
My OS is windows 7 and I have Adobe Acrobat 7.
I found an old CD and that was written by me long time before on my desktop computer.
That time I was using Windows 2000.
Now the problem is I can't open PDF files on that CD with a corrupted error message.
But other office files can open.
Please tell me how to fix corrupted acrobat files?
How to fixing corrupted acrobat file?
Hello there,
Well its a very common problem now days, did you update your acrobat reader? Anyway did you try downloading acrobat reader 8, and reopening the file in Acrobat Reader 8?
If still the problem persists then the possible chances are- File Corrupted, so if that's the case, I would suggest you to repair the file using SysInfo Tools PDF Recovery v3.0. It's the easiest software on heaven to repair corrupt files.
You can download a free trial version from the link given below – https://www.sysinfotools.com/recovery/pdf-recovery.php
Hope it helps
