How to flip webcam image for Mac?
Hello techyv,
How to flip webcam image for Mac? I am taking pictures from my webcam in my Mac operating system computer and I want to flip it on the right side and send it to a friend. I have to flip almost 200 pictures of mine during a vacation trip. How can I possibly rotate those images? What application needed?
Expecting some help from you guys. Thank you.
Best Answer by Molina Kevin
Answered By 0 points N/A #182138
Hi!
You can edit or flip image by using Photoshop any version. If ever you do not like the idea you can also use Paint application if Mac computers have that or if you have that installed in your mac, then you just have to save it as a jpeg file.
Another choice is you can download Flip Builder, Flip Image for Mac software. It will provide and guide you to build animated gallery also not just help you flip. It can be run on many different versions of Mac devices, like Mac OS Leopard, Mac OS X Snow Leopard, etc. Just import your desired images, arrange content order, set the theme, then output.
Good luck! Best Regards!
Answered By 0 points N/A #182137
Greetings
Its really a honour that you suggested our site for your query
In Mac you can rotate the pic by creating a new folder on desktop right click control click to attach folder action
you'll get the folder actions scripts then you have to go down to the image rotate and rotate your image rather left or right and attach and then just drop the images in that folder its as simple as that sir
Regards
Lopes Natanne
