How To Force Active Directory Replication Between DC
There are two domain controllers where I want to replicate a directory. The directory is in use. How can I force active directory replication between two domain controllers?
Step 1: Open Active Directory Sites and Services from Administrative Tools by clicking on the start button.
Step 2: In the hierarchy shown on the left, Expand Sites. And the site you want to replicate.
Step 3: Expand servers and NTDS Settings of the server connected.
Step 4: Right-click NTDS object and select Replicate now.
Step 5: A dialog box with information about replication will be displayed. Check the info and press OK button.
The active directory will be replicated as required.
