How to format a cd in windows 7 easily
How to format a cd in windows 7? How can I solve this problem? Do you have any suggestions to resolve the problem? Can anybody help me to solve this problem?
To format a CD or DVD in windows seven, follow these steps:
First, insert a rewritable or recordable disc into the computer's DVD, blueray or CD Disc burner.
Next, the dialog box of AutoPlay will appear, click on Burn the files to the disc using the Windows Explorer.
Next, Write the name for the disc in the Disc title.
Click on any formatting options from the following:
Like a drive of USB flash -Here, the disc usually use Live File format System.
With a DVD/CD player-Here, the disc usually use Mastered system format.
Then, Click on Next in order to prepare your disc.
Hopefully, this answer is helpful, easier and clearer steps to fix the problem.
