How To Format A Dell Laptop To Clear All The Personal Data.
When your desktop crashes or faces some problems or you want to clear all your data from it, you need to restore/ format it. How to format a Dell laptop?
HOW TO RESTORE?
Backup all your files and folders. Switch off your PC.
Disconnect all the I/O peripherals.
Restart your computer and press F8 key when the logo appears.
You will be redirected to Advanced Boot Menu.
Select Repair your computer.
Go to system recovery options menu and select a layout.
Login as an administrator.
Go to Dell Factory Tools and then Dell Factory Image Restore.
Click on next. Check the box which states ‘Yes, reformat hard drive and restore system software to factory condition’.
Select on finish.
Restart your desktop.
Restore the files from the backup.
