How to format flush drive in linux?
Hi Riley,
This is very easy command to format your pen drive,
You need to follow a few instructions which I have given below. You just type following command…
mkfs –t ext4 /dev/sda
“sda” is your device name, it can be sdb, sdc also.
You can get more help in following site: https://tecadmin.net/format-usb-in-linux/
Sharlene Rubi
To format your USB device in Linux machine.
First, you must "unmount" the device but leave it plugged in. "Unmount" is equivalent to "Safely Remove
Device" in windows .To unmount, use command
umount /dev/sdf
Once the device has been unmounted, execute the format.
mkfs.vfat /dev/sdf
The device will be formatted, and then you can remount the device eventually.
Best Regards,
Jerameel Cyrus Tubon
