How to format a Nokia C5-03
How can I format my new Nokia c5 – 03 phone and get it started I have it start from the box but don't understand the directions on the phone menu I need simple and direct ways?
Hello Quiqui,
When formatting a Nokia c5 – 03 phone, you can either choose to use a hard reset mechanism or a soft reset.
Hard Reset:
Note that this procedure will get rid of your data and all the applications that you have installed. It will restore the settings of the phone to the default factory settings. This is how you do it:
Soft Reset
With soft reset, your data will remain intact. No harm will be caused to it. What this procedure does is to only restore the .ini files from the flash ROM on board memory of your phone. The following is how you work with a soft reset:
Carl
There are several ways to do so. But I'd like to say about one specific way. That is
Turn off the device > Pull out the battery and reinsert it back again, then power it ON > Simultaneously press and hold
*+3+Cal button(Green/OK)
After doing this your phone will restart again and all settings will be on default level.
Therefor phone is formatted.
