How to format photos to ico?
Hello everyone! I am a newbie here. I have here over a hundred photos that need to be formatted to ico. Anybody can give me a step by step tutorial on how to format photos to ico for my Windows PC? Thank you.
"There are a lot of ICO converter software that you can use. One of which and the most popular is Photoshop.
Follow these steps to convert the photos to ICO in photoshop.
1. Install the plugin from telegraphics.com.au/sw/#icoformat on your computer.
2. Click on the Windows 32 or 64-bit version, Whichever you use and install the .zip file on your computer.
3. Extract or unzip it. Right click on it and select Extract files. You will see it contains 3 files:Â the plugin, readme, and the
Gnu Public License.
4. Copy the file names plug in or you can drag and drop it to C:Program FilesAdobeAdobe Photoshop CS5Plug-insFile Formats.
5. Relaunch PhotoShop. Go to "File," "Save As" and choose the .ico file format."
