How to format a USB flash disk to ext2 using Windows?
I have a computer running on windows XP and I want to format my 16GB USB FLASH DISK to ext2 filesystem. I have heard this can only be possible running on Linux Can this be possible on windows?
Yes it is possible for your computer running Windows XP to format your 16GB USB flash disk. Just simply follow these steps:
Best regards,
Heather marie
You can first change the file system and then you will be able to perform the format task. To change the file system you need to select manage form the menu you will get by right clicking on my computer icon, then go to disk management tab and perform the task.
Smith Thompson
