I would like to forward ports to a Netgear FVS336Gv2 but when I tried it, it gave me an error. Is there a way to forward ports to this device with lesser hassle? Is there a configuration that I missed why port forwarding did not work? Your help would be much appreciated.
How to forward ports with Netgear FVS336Gv2
It is likely that you did not configure your router correctly. It may be helpful to review the list of port numbers on the manufacturer website. It is also helpful to review the manufacturer instructions and cautions for your particular model. Note your model and its unique characteristics before seeking instructions. You can also utilize guided software for this purpose. You did not indicate why you are port forwarding and what devices you are using, so I cannot provide specific information pertaining to that. There are scores of applications for various devices that simplify this process, but many of them still require that you conduct a specialized configuration of your router.
