Hello experts,
How to generate random id excel? I am assigned to make some unique usernames for a specific website with the same password, I need at least 500 usernames and I am having hard time to make this happen soon. I would like to ask if there are possible licensed software that will generate random id excel. Thank you.
Hi Christine Turner,
You can use Kutool to generate the random string. Kutool can generate random numbers, random text string, or random numbers & text & symbols with all kinds of characters, including letters, numbers, special characters, space, and even custom strings. To generate a random string please follow the following steps:
1. Start the Ms-Excel.
2. Click on Kutool and then click on modify. Click on Range Randomize Utilities.
3. In the Range Randomize Utilities dialog box click on Insert Random String radio button.
4. Configure the string settings check characters options, define strings length and custom strings.
5. Then click OK.
I hope This will work for you.
