Hi Experts,
I want to get 3gp video free download.I tried by googling but could not get correct version.Can someone tell me how to download the latest version of 3gp video for free.Thanks.
Zubin Lennon
How to get 3gp video free download?
Hallo Zubin,
Where did you try downloading the 3gp video downloader, because you can readily get it from various download sites online for free, some of which include the following:
So just access any site of your choice and then look for 3gp video downloader free and you will be able to find the application that you want. Be sure to check the reviews of the people who have downloaded the application for many results may be listed but not all of them are working properly.
Carl
Hello Zubin,
Depending on what you want to download, there is a lot of software that can download 3GP videos. You can purchase from the internet. It can download different video files such as a 3GP for your mobile. There are download managers that asks you to download videos while they are playing, and all you have to do is click and choose the type of file you want the video to be (3GP, FLV, MKV, etc..).
You can also download a video converter and convert the videos that you would like.
1. Download a converter from the internet (you can find some on Google)
2. After you have successfully downloaded the converter, you can now install it. Be sure to check for viruses just to make sure your computer is safe and secured.
3. Choose the file that you want to convert and wait for a little while.
I can also give you specific steps and other things if you want.
Hope this helps you.
Reaiu Hathy
Dear Zubin,
If you have a fast internet connection why even bother downloading an installing a whole software when you can just go to this website: http://www.ixconverter.com
This website is a converter in itself and also serves 3gp format (your need)
So if you want download videos in 3gp format for free just paste the link on the bar on the main page of the link I gave you and click on the yellow "Convert" button. Shortly afterwards, your 3gp video will be ready for you to download and enjoy.
Hope this saves you alot of trouble.
Regards
Kumay Edwards
