How To Get Administrator Privileges To Control Processes Of OS.
Asked By 15 points N/A Posted on -
Administrators have the power to control the aspects of Windows 7 operating system. These aspects include installation and removal of drivers and programs or making changes in registry. Trusted employees are given the administrative powers in a business. How to get administrator privileges?
Answered By 270 points N/A #200499
If a desktop has a administrative account, we can create more accounts with these privileges.
To access the existing one:
1) Open start menu.
2) Search for Run.
3) Enter cmd. You will be redirected to Command prompt.
4) Type net user administrator/active yes.
5) This will enable the hidden account.
6) To access the existing account, sign out.
To create a new account:
1) Open start menu.
2) Go to control panel.
3) Go to user’s accounts and family safety, then open user’s accounts.
4) Select Manage another account.
5) Press ‘create a new account’.
6) Select administrator.
7) Choose a new account and create a password.
Answered By 590495 points N/A #344661
In Windows, if you want to have a user account with administrative privileges, you need an administrator for this. You need to ask the network administrator or a user on the computer that has administrative privileges that will make changes to your account. To change the assigned permissions to your account, the local administrator needs to change your account type from “Standard user” to “Administrator.”
There are only two account types available in Windows: Standard user and Administrator. The “Standard” account or “Standard user” account is the basic account assigned to normal workstation users. This account type doesn’t have the ability to install applications and change system settings that can affect other users or the security of the computer.
“Administrator” accounts have complete access to the computer and can make any desired changes. They will be prompted for their password before making changes that affect other users depending on the notification settings.
