Hi Experts,
I am having adobe flash cs3 on my desktop.I want to get adobe flash cs3 games source codes.I did heavy research on this.If you can tell me any recommeded text books to get the source code.Thanks.
Shirlyn Winchel
How to get adobe flash cs3 games source codes?
Hi Shirlyn,
I am also using adobe flash cs3 on my desktop. I am using https://www.adobe.com/devnet/actionscript/samples/game_1.html for complete tutorial about adobe flash cs3 games source codes. I have find the complete tutorial on this website. and this is very helpful for the adobe flash cs3 games source codes. Thanks!
Hello Shirlyn,
To get adobe flash cs3 games source codes, you will need to use the following procedure:
First, you will need to open the FLA file.
After that you will need to import and then convert the phone.
Next you will set up the timeline, and the slide in.
After that you will test the movie by pressing Command-Return. You will need to see a nice slide-in animation from the left of the screen.
And then scale it up.
After that finish up the animation – you will need to test the movie and see if you have got a nice animation effect.
If that is, you can go ahead and convert the code as follows:
You will need to choose all of the frames on the phone layer by clicking-and-dragging a selection over all frames.
After that you Control-click on the selected frames and then select Copy Motion as ActionScript 3.0.
That will open a window that requires the instance name of the animation.
You will need to enter “phone” and then click OK.
Carl
