How to get Aimersoft DVD to PSP converter suite
A few days ago I wanted to watch some movies on my PSP 3004 console.
I downloaded a converter because I had the movies in my PC and just wanted to make the into the right format.
Unfortunately the quality was low and also the conversion took about 2 hours.
And now, I want you to help me a bit with Aimersoft DVD to PSP converter.
I have heard that it's a better software then a typical converter.
Can you please tell me if indeed the quality is good and if the conversion time is decent?
Also if you can tell me how to get this software, I would really appreciate it.
