Hello everybody… I need your help to find me an application for PHP search engine script free download so that I could automatically scan and index web sites that I visited. I need it installation procedure as well. Thank you for helping me.
How to get and install PHP search engine script free download
I have searched so many sites one way is find below link and installhotscripts.com click listing type zoom search engine in search bar
Another way is goto below link and see sphider, tsep are free to download go to javascriptkit.com and click how to category then type for php software
Another way is click below link find zero blast freeware software for PHPgo to sourcecodeonline.com click freeware type then click sources and search for php in search bar and install software
Hope these shall help you
Thanks
I can give you some names of software and address, where you will find it
1. Zoom search engine- It is easy to use and install and no requires complicated server- slide setup.
2. Devel search engine PHP script- You can use it to add search functionally to your website. It is easy to use and install.
Search here- http://www.webhostingtalk.com
Good Luck
