Hi.
Recently I have downloaded a Movie in HD print and now trying to separate audio from it.
As I want the same quality of audio like in the video.
I have tried different tools to convert but bad quality of sound is raised.
Any solution related to get audio from a movie clip mac as it has become challenge for me.
How to get audio from a video clip mac?
Did you try VLC yet?
Follow the steps: –
Click on Media, scroll to Advanced Open File.
In the File Tab, click on Add and select the video.
Click the Convert button
On the next window, enter the output path.
Select the encapsulation method WAV
Still quality is not guaranteed to be of high as extraction may result in depreciation.
Hi Kristopher,
There is a nice site with an in-depth tutorial on how to separate audio from a video.
It offers a program for Mac and Windows, here is the link.
Some people also use an application called Garage Band to convert videos to audio.
Simply drag the video file into the program, delete the video track and export the file as MP3.
