Hi guys,
I have important data in a CD but some how it is now damaged and don't know how it got damaged but the data is really important to me. So please help me by answering is there any way I can get back the data from that CD and if yes how can I do this and is there any software that may help me.
points
How to get back data from damaged CD?help
CD/DVD is one of the worst data storing method today as it becomes damaged after a certain period. If a disc is corrupted, there’s a little chance of getting the data stored on the CD/DVD totally corrupt-free. There are many software that does the job perfectly.
CD Recovery Toolbox is a good software that will copy all the files from your damaged CD to your favorite destination. Download CD Recovery Toolbox.
CDCheck, Unstoppable Copier are also other good software in this purpose. You can use any tool to recover your data from CD but careful, if you’re recovering any software, it’s better to retrieve another copy of the installation.
There are two ways to recover data from damaged CD.
1. If there are scratches on the CD so try to remove or fill those scratches by using nail polish or any other ultra-clear filler. After that polish your CD by using any shiner or you can even use glass shiner spray. Put your CD in your computer and transfer the data to any other source.
2. If this trick does not work or you want to go for an easy way then download software ""Recover Disc 2.0"".This is a powerful software that will retrieve your data from damaged CD/DVD
