Hi guys,
I want to ask how to get back data from my damaged SD card. I used this SD card in Samsung Galaxy S4 an I don't know how it is damaged now, but I want its media badly all my images are saved in it and important data also. So please suggest me an application or software that may help me.
points
How to get back data from damaged SD card in S4?
There are many softwares that do this recovery job. Most of them are just junk, but some are tremendously powerful and able to do the perfect job.
The best software, in my opinion, is MiniTool Power Data Recovery. It’s very powerful enough to recover data from any damaged media, from lost partition on HDD and recover deleted files as well. All you have to do is separate the SD card from your Galaxy S4, connect it with your PC with any card reader and let the software do its job.
There are also other softwares that do the same job. CardRecovery, Zero Assumption Recovery are also good ones.
If the space where the lost data used to write is overwritten by other data, the files are lost forever. Getting them again requires retrieving another copy.
How are you? There are 3 simple steps to take back missing data from wrecked Android Galaxy S4 directly. To do so ensure that your broken Android can be started and detected by your computer.
Step 1 : Make sure the “USB debugging” before building connections between your broken Android and your Computer.
Step 2 : Explore and inspect your busted Samsung for contacts on your computer. Then left click on “Allow” option. After that you should click on “Start” option. Make sure that the charge of your mobile is more than Twenty percent.
Step 3. Explore and retrieve missing data on broken Samsung S4. Check the deleted contacts by scanning. You can preview all the contacts by clicking the button “Contacts“ on the left column. Finally, click on “recover” option. Learn more.
Moreen Jamnelly.
