Hi Experts,
I am having a Samsung mobile phone.I want to get battery doctor for Samsung wave.Does anyone know about this software.I want to connect my phone to the pc using this software.Give me the link to download this software.Thanks.
Zubin Lennon
How to get battery doctor for samsung wave?
Hi Zubin,
I recommend you can use the Kies Software to connect your phone to PC.
I found that Battery doctor is used for the Battery related issues. It increase your battery backup. It is not used for connect to the PC.
Thanks!
Hi there user:
I suggest you to download the ultimate version of Juice Defender; you can purchase it via Google Play Store in your Samsung Mobile Unit. Battery doctor is okay, but nowadays I noticed users more often use Juice Defender for their Samsung Mobile than any other software. Anyway, it’s up to what you desire, you can try them both. Visit Google Play Store for more. Â
Thank you for asking via techyv.com
