Trevor Jhon
40 points
Posted on - 10/22/2012
Hello experts,
How to get a chance about Corel draw 120 repair? I got some Corel draw 120 files that was corrupted by some malicious ware viruses over the internet and was wondering if there are some chances to fix it or recover those files from being damaged. Tell me some details about this. Thank you.
How to get a chance about corel draw 120 repair?
Corel Draw is software that helps you to build and revise vector images. It has lots of tools that you can apply to change your picture, such as a tool that helps you to insert page layers or a crop tool. It is like to Photoshop. Recovery for Photoshop is recovery data program software for corrupted files.
Best regards,
Heather marie
Hi there,
Maybe you would like to try Corel Draw Repair Toolbox that can be downloaded from the following link:
Business is $149 and Site is $300.
Have it downloaded to your pc with installed CorelDraw and run to repair corrupted cdr files.Â
