How to get chipmunk on Snow Leopard
Hi techyv,
How can I get the new Lion photo booth effects like chipmunk on Snow Leopard without upgrading to Lion?
Cheers
Hi techyv,
Cheers
If you are looking to get the chipmunk photo booth effect on Snow Leopard without upgrading to Lion, you can use a plugin. Photo booth is a free download for the Mac that adds some pretty cool effects to your photographs and your videos to spice them up. Your photographs and videos will never be boring ever again. The chipmunk photo booth effect will turn the faces in your photographs and videos into a chipmunk.
Another way to get the chipmunk photo booth effect on Snow Leopard is to upgrade your Snow Leopard version to 10.6.2.
This will fix the problem with crashes that occur in the 64 bit mode.
