Dear friends,
How can I get Chrome to display the HTTP error returned by the server rather than the "friendly" error:
Page could not be loaded The link you specified does not work.
This may either be the result of temporary maintenance or an incorrect link.
How to get Chrome display HTTP error rather than the ‘friendly error’?
For the text of the error message I suggest that it may be EPiServer error page, not a Chrome friendly message.
In the version of chrome 4.0, the friendly error begins with “Oops! This link appears to be broken” and contains alternative links, a Google search box.
You can ON or Off it by going to the wrench menu – Options – Under the hood, then check or clear Show suggestion for navigation errors.
Regards
