Hi Experts,
I am having ms word 2007, and I need to get collegiate font for ms word.
I am currently having the font but do not know how to add them to ms word.
I tried to paste it to ms word fonts but failed. Please advice me on this.
James Yorath
How to get collegiate font for ms word
Search for a folder named Fonts
If you are using Windows 7 then just click on Start button and type Fonts and press enter.
Here in this folder copy/paste all the collegiate font files that you have downloaded.
Then Open Microsoft Word and you will have your Fonts!!
Good Luck
Hello James,
First of all, you will need to download the collegiate fonts, and then do the following;
You will need to go to daFont and then select any font that you wish.
Download that font and then save it to the following folder location on your computer: C:>Documents and Settings
After you have saved it, you will need to open it in the Documents and Settings folder.
After that you will click File and then Extract All.
In case you don't have that option you will need to download an extractor.
After that you will have full access to the font now, and therefore you can do anything you like with it.
Carl
If you want to use collegiate fonts in Microsoft Office Word 2007, try downloading from the following websites:
Once you’ve downloaded the fonts you like, installing them is easy. Click “Start”, “Control Panel”, “Appearance and Themes”, and then click “Fonts” on the left pane. On the next screen, click “File” and then “Install New Font”. Navigate to the location where you downloaded the fonts then click “Select All” and then “OK”.
Once the fonts are installed, you can now use them when composing a document in Microsoft Office Word and other programs. If the fonts you downloaded are in ZIP files, unpack or extract them using 7-Zip or other file compressors like WinZip and WinRAR.
