How to get continuous ip changer free?
I need continuous ip changer free software which will change the IP address continuously on my PC. I need the free software to do this task. Recommend me the name of this kind of software so I will be able to use it. I am waiting for the reply from all users.
Best Answer by Wagner Desantiago
Answered By 5 points N/A #160027
Hi Jermainporterr,
There are two ways to accomplish this task. One is Proxy and the other one is the (LOCAL) IP changer.
  • Dynamic IP Changer v1.0 is the software that can do this task without any glitch.
  • If you want to change your IP through Proxy then Elite Proxy Switcher is one of the most widely used soft-wares in proxy switching. The free version of elite proxy switcher can serve the basic purpose of changing the IP address through different proxies and in full version automatically.
  • You can also use Free IP Changer that serves the same purpose.
Thanks
Answered By 5 points N/A #160028
Hello Jermaineporterr,
Another way of changing IP address is by using an add-on. You must use Firefox for this. By this add-on you can change the IP address of any country at any time and you will be showed from that particular country rather than your real identity.  It's very easy to us. Follow here:
Visit here for Firefox add-on.
1. After going to the site click "continue to download " and then "Add to Firefox".
2. Then wait for it to install and restart Firefox.
3. Now visit Hide my ass and choose your preferred country or IP and copy the Ip address with port.
4. Now click the blue signed FoxyProxy and on the left side click add new.
5. Then type the IP address in " host or IP address " field and port in the "port" field and click ok.
6. It's all done now, in the select mode choose your IP and star browsing.
Thank you,
Wagner Desantiago
