Hello experts,
How to get a download for icon maker freeware? There are some shareware version over the internet but I can’t find the freeware version, will you share with me all the possible websites that I can be able to get a software for icon maker freeware?
I hope you can help me, thank you.
Icon Maker can create and edit cursors, animated cursors and icons – with the general editing effects and tools, export icons in a color depth and standard size (16, 24, 32, 48, and 64) and bring in icons from pictures and data files. Download Icon Maker
Best regards,
Heather Marie
LyanaHay
You can get freeware software as I am listing some of them:
1. Greenfish icon editor pro
2. IcoFX
There are some websites where you have to make an account and login so that you can make your own design and download .ico, file some of them are:
1. http://www.rw-designer.com/online_icon_maker.php
2. www.sherv.net/icon-maker/
Hi Danield,
I've found the perfect icon maker for you. It is free, easy to use and very user friendly. It supports all types of standard sizes of icons. It even supports monochrome, 16 bit, true color and true color + alpha channels types of icons. You can even extract the icon from any other file using this software.
You can download the software from the link given below.
Link: http://www.icon-maker.com/
Alternatively, you can even use an online icon creator. It would perform the same operation, and you would not even have to download anything. Everything can be done on your browser. You can have a look at it at the link given below.
Link: http://www.genfavicon.com/
Hope this helped!
Drianna allen
