Emaily Rawa
10 points
Posted on - 10/18/2012
Hello experts,
How to get a download for windows free scan repair? Anything free computer scanning repair program will do as long as it can help me regarding computer issues or problem; I hope you can recommend the best one.
Thank you.
Hi
The Microsoft Safety Scanner is a free downloadable security tool that provides on-demand scanning and helps remove viruses, spyware, and other malicious software. It works with your existing antivirus software. It expires 10 days after being downloaded. To rerun a scan with the latest anti-malware definitions, download and run the Microsoft Safety Scanner again.
Get it at : http://definitionupdates.microsoft.com/download/definitionupdates/safetyscanner/x86/msert.exe
Hi Emaily Rawa,
I have seen a lot of possible solution with your problems but I choose only one link for you to have a reference. I have attached it below:
This link below may also be helpful:
Hope that it would be helpful enough.
