My friend told me that I can get all my emails from different accounts into one. I have 5 Gmail accounts and logging in to all of them in the morning is a headache. Is it true that I can view all emails in one account? What are the steps needed to set up the accounts?
Any ideas will be appreciated.
How to get Emails on one Address
Yes it is possible to get all you emails regardless of how many email accounts you are using and regardless of email service provider. Thee are several eMail manager programs that are offered in the market so it's really up to you to choose what you like. However, I use Mail Collector and it is what I recommend fro obvious reasons. Click the link here to check how it can solve your problem:
https://www.mail.com/mail/mail-collector/
This will be very easy to use but and very efficient way to do this.
If you are using windows 7 please do the following.
1. Download Microsoft outlook.
2. Go to start and open the menu.
3. Type mail in the search bar.
4. Open the mail and enter email account that you have.
5. After entering the details select add another and add all you want.
6. Once added search for Outlook and open Outlook.
7. All your mails will be there.
Hope this serves as excellent answer! 🙂
