Hi Experts,
I want to get Epson stylus dx 6000 scan windows 7. I need to scan my Epson PC thoroughly. Can anyone tell me how to perform this scan. Can I try it using control panel? Give me step by step instructions.
Jafet Windsor
How to get epson stylus dx 6000 scan Windows 7 ?
Dear Jafet,
Your Epson PC running windows 7 can be thoroughly scanned using an anti-virus and anti-malware software. I recommend using AVG. To Download the latest version of it, go to the following link and click on the green download button on the top right corner.
It may take a while to download. Once downloaded, a setup will guide you through an easy installation process.
Then AVG may attempt to update itself. After that you can scan your whole computer with it. Even you can scan specific drives and folders if needed.
Hope this solves the issue.
Regards
