How to get erd commander to usd bootable?
Please say, how to get erd commander to USB bootable?
I need the algorithm for versions of erd commander delivered with MS Dart for Windows 7 USB/DVD Download Tool.
It is a system which gives access to modify windows NT setup disks. It also allows the user to not only to edit system files but also the registry files. It also gives access to removable devices to edit damaged files.
Hi Jair,
The steps to create a erd commander USB bootable are as follows:
1) Download the YUMI mutliboot tool from the YUMI official website
2) Install the tool in the system
3) Select the USB flash drive
4) Select the bootable ISO and browse to the ERD50.iso file location and open it
5) Click 'Create', the ISO files will be imported on the USB flash drive
6) After the process is complete, select the option where you want to boot into the system
7) After selecting the option, the process will be completed
