How to get a fast activation email?
Hello Experts,
How to get a fast activation email? Most of the time I don’t get some activation email from the registration of a specific website and I am very confused why is this happening, there are also times that I cannot received a confirmation or activation email which is very important during registration. Now can you give me some advice on how to get a fast activation email?
Thank you.
Best Answer by cathy emrald
Answered By 0 points N/A #165371
Hello Christine,
If you don't get some activation email from the registration of a specific website maybe it's because of internet traffic. Or maybe your email is too crowded of emails. I suggest to send again a registration on a specific website to get a new activation code. If the problem still the same maybe you should contact your email provider to fix the problem for you.
Answered By 5 points N/A #165372
Have you check on other folder such as the spam folder? When you create an email account, you will be asked to click the confirmation sent in your email to activate it. After registering, do not close the window where it says, click to activate the confirmation code in your email address. Check it on your inbox.
If you don't receive any, there is a link that is asking if you did not receive any confirmation, try to click the resend the confirmation link. Or contact the email support team and tell them that you are not receiving any confirmation or activation code.
Answered By 0 points N/A #165373
Hello Christine,
I also had this issue once during registration but eventually i found out i miss spelled the email address. Make sure that you have given a correct email address. Read it once before registration and try to check your spam and trash folders as well. Gmail sends all this kind of emails to either trash or spam folders. If you are still not getting the activation email, change your email service provider to activate the account.
Thanks
Answered By 5 points N/A #165374
In your case what you are asking is totally out of control from you. Because if the email gets more time to receive it’s not you problem it’s a problem with the sender. Most of the time you cannot see those automated emails directly in your inbox in that case you need to check your spam folder in the mail account.
